Activity Forums Adobe Premiere Pro Is there a way to adjust offset sync in an existing merge clip
  • Is there a way to adjust offset sync in an existing merge clip
    Posted by Gunleik Groven on August 19, 2016 at 3:09 pm
    Here is what I wanna do:
    I have a merge-clip that comes in pre-formatted with metadata, TC sync and scene/slate/date info, but for whatever reason the TC doesn’t match 100%
    I can pull it into a sequence, unlink and re-sync, but that is not reflected in the master (original) merge-clip.
    I would like to have the same option as with multi clip where I can manually refine the sync on clapper if necessary, without breaking the file and metadata relations in the “master” merge-clip.
    Gunleik
    https://gamp.io
    Gunleik Groven replied 10 years ago 1 Member · 0 Replies
  • 0 Replies
