Activity Forums Adobe After Effects Is there a way to achieve this smear-like effect on the ball in after effects?
  • Michael Szalapski
    March 10, 2025 at 3:58 pm
    Did you upload the right video? I don’t see any ball.
    Just based on your description, Trapcode Echospace lets you repeat a layer with offset animation and progressive transformation (that is, scale getting smaller), if you have Red Giant things.
    If not, you could try Dan Ebberts’ https://www.motionscript.com/mastering-expressions/follow-the-leader.html
  • Graham Quince
    March 11, 2025 at 9:10 am
    That looks to me like a combination of Fractal Noise with the scale for width and height different, then the Polar Coordinates effect to turn the noise into a circle. With keyframes on evolution and offset, you should get the streaks you’re after.
