Activity Forums VEGAS Pro is there a way in vegas to duplidate this kind of look?
  • is there a way in vegas to duplidate this kind of look?
    Posted by Joseph Testa on July 6, 2011 at 12:30 pm
    Please see attached photo, i’m looking thru the event fx but can’t quite figure out how to pull it off, or should i be using something else to alter the photo and then just import it into my production?
    thanks, joe
    Daniel Hughes replied 15 years, 2 months ago 3 Members · 2 Replies
  • Joshua Smith
    July 6, 2011 at 1:20 pm
    Are you trying to alter the video to look like the photo or are you trying to alter the photo to fit the look of your production? I know that between Color Corrector or third party plugins like Magic Bullet and Magic Looks you could sorta produce the same color and contrast as in the photo. For the more cartoon look you try some free plugins from NewBlueFX.
    Check this plugin out: https://www.newbluefx.com/cartoonr/
    Hope this helps!
    Joshua
  • Daniel Hughes
    July 6, 2011 at 1:28 pm
    Sure!
    You can do it by dropping a Brightness and Contrast and Gradient Map onto your event or track.
    In Brightness and Contrast bring Contrast and Contrast Center right up, but not all the way (You can do what you want really), and bring the Brightness accordingly until you find a balance and the levels seem right.
    Now go to your Gradient Map and try to arrange something like this:
    Play about with it til you get the look you want 🙂
    With gradient map the bar gives a dark to light sort of spectrum for you to then replace all of the dark colours in the clip with, for instance, brown, all of the mid colours with orange and the brights with yellow.
    Hope this helps!
    P.S. Apologies, my example is very rushed!
    Daniel Hughes
    Amateur Writer, Director,
    Director of Photography
    United Kingdom
