Activity Forums Adobe After Effects Is there a shortcut to extending Comp to match footage layer?
  • Is there a shortcut to extending Comp to match footage layer?
    Posted by Sean Worsell on July 24, 2011 at 2:24 am
    I find this one comes up a lot for me. After you have created your first comp in a project, AE remembers the comp length so any new comps are of the same length. So you drop your next footage layer into this new comp…but the comp isn’t long enough. It was the right length for the last footage you worked with, but too short for the new one. Is there a quick and easy shortcut (maybe even a script) to “extend comp to match layer” so that the comp then becomes the same length as the footage layer?
    Michael Szalapski replied 15 years, 1 month ago 2 Members · 1 Reply
  • Michael Szalapski
    August 2, 2011 at 8:55 pm
    Just drag your footage onto the make new comp button.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
