Activity Forums VEGAS Pro Is there a shortcut for changing the preview settings?
  • Is there a shortcut for changing the preview settings?
    Posted by Bryan Powers on July 4, 2011 at 7:33 pm
    I’ve been frustrated lately with the fact that, as the timeline plays, the ram continues to fill up making playback gradually more and more sluggish. I’ve noticed that toggling between preview settings ( auto to full or half to full or full to auto) clears the ram and smooth playback resumes.Is there a script or shortcut that makes this fairly easy work around even easier. I’d like it to be as easy as say cntrl+s which I almost do without thinking now as I work. Thanks!
    Bryan
    https://www.hindsightweddingfilms.net
    John Rofrano replied 15 years, 2 months ago 3 Members · 4 Replies
  • John Rofrano
    July 5, 2011 at 3:38 am
    [bryan powers] “Is there a script or shortcut that makes this fairly easy work around even easier.”
    Here is a script that I just wrote for you which will do this. Cut and paste it into a file called TogglePreview.cs and place it in the Script Menu folder and then just assign it to a key combination to it:
    //* Program: TogglePreview.cs
    //* Author: John Rofrano
    //* Updated: July 4, 2011
    //* Description: Toggles the video preview to clear dynamic RAM
    //* Copyright: (c) 2011, John Rofrano, All Rights Reserved
    using System;
    using System.Diagnostics;
    using System.Windows.Forms;
    using Sony.Vegas;
    public class EntryPoint
    public void FromVegas(Vegas vegas)
    try
    VideoPreviewSize originalSize = vegas.Project.Preview.PreviewSize;
    vegas.Project.Preview.PreviewSize = VideoPreviewSize.Full;
    vegas.UpdateUI();
    vegas.Project.Preview.PreviewSize = VideoPreviewSize.Half;
    vegas.UpdateUI();
    vegas.Project.Preview.PreviewSize = originalSize;
    vegas.UpdateUI();
    catch (Exception e)
    MessageBox.Show(e.Message, "Critical Error", MessageBoxButtons.OK, MessageBoxIcon.Stop);
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Bryan Powers
    July 5, 2011 at 4:25 pm
    Awesome John! Thanks!
  • Matt Crowley
    July 5, 2011 at 5:49 pm
    The RAM shouldn’t continuously fill up with preview data unless you have set the Dynamic RAM Preview Size to something very high. Reduce the setting to something sensible (depends on your system RAM, OS etc) and you should find that Vegas doesn’t hog RAM for the preview.
  • John Rofrano
    July 5, 2011 at 6:17 pm
    You’re welcome Bryan. Let me know how it works out for you.
    ~jr
