Activity Forums Adobe After Effects Expressions Is there a ready made script to search/edit a specific parameter in multiple effects
  • Is there a ready made script to search/edit a specific parameter in multiple effects
    Posted by Yan Da on April 10, 2016 at 8:37 pm
    Is there a ready-made script to search/edit a certain parameter in multiple effects across layers and comp. I searched aescripts.com, but can’t find any. There are scripts to search expression, or effect names. But not specific effect’s parameter. Using AE’s native search function, you can’t get a specific effects parameter if it shares the same name within other effects that you don’t want to edit. For instance, I want to search/edit “path” parameters only inside 3D stroke effect on multiple layers without showing other path parameters.
    Beside, for beginners in scripting. I wonder if it’s difficult to learn to write a script doing this task.
    Miguel De mendoza replied 10 years, 4 months ago 2 Members · 1 Reply
