Activity Forums Apple Final Cut Pro Legacy Is there a quick way to make all clips a specified length and apply a transition
  • Is there a quick way to make all clips a specified length and apply a transition
    Posted by Max Huggett on July 23, 2009 at 11:33 pm
    Hi people
    I have stack of 15 second graphic overlays, that where rendered out of After Effects as a single QT file.
    So far, i have quickly taken the first 6 seconds of each clip and layed them down, however my selected outpoints have been rough, which have meant, each clip is in between 5 seconds and 7 seconds in length.
    I would like to make each 6 seconds long. Is there an easy way to trim them all, so that they are this length.
    Furthermore, i would like them all to have a 10 frame dissolve/fade at the end of each clip. Can this be done in one go also, or is this an item by item case by dragging on the transition to the end of each clip.
    Thanks for any assistance.
    Max
    Victor Perez replied 17 years, 1 month ago 2 Members · 1 Reply
  • Victor Perez
    July 24, 2009 at 4:39 pm
    As for adding transitions to a number of clips in the sequence at once…
    Select the transition you want and ‘Make Default Transition’
    Duplicate your sequence (incase something goes haywire
    Place your sequence playhead at the head of the first clip you want to add transitions to
    Highlight all clips ahead of the playhead and drag them up to ‘Insert with Transition’ in the Canvas
    Final cut will now add transitions to all clips being inserted again into the timeline
    Victor
