Is there a more efficent workflow?
Hi
I have recently started editing using FCP and have encountered a problem I was hoping someone on here could solve.
Namely I am being given dub sheets to work from that list edit points that I need to type into the viewer window and then use the in and out points to mark them before placing them onto the timeline. However this leads to the problem that if I’m interrupted I can sometimes forget which edit i’m on. Or at the end when I goto check my edit points back and some don’t look right I then have to type in and check the in and out points into the viewer to make sure I got the correct timecode. Which seems a quite loborious task.
Is there any way this process can be speeded up by having a window where I can type all of the edit points in at once and then I can quickly scan them to make sure the timecodes are correct before entering them in one go. A sort of EDL but without having to export it into FCP first.
