Activity › Forums › Adobe Premiere Pro › Is there a keyboard shortcut to move a clip from Track V1 to Track V2?
  • Is there a keyboard shortcut to move a clip from Track V1 to Track V2?
    Posted by Paul Boone on June 18, 2015 at 5:27 pm
    Hello,
    In my current workflow, after I’ve selected all the possible clips I might use, I do a second pass where I move the best clips up one track from V1 to V2, and I used to have a shortcut in FCP to quickly move the clip up one track. I forget the exact shortcut, but when a clip was selected, it was something similar to holding CMD & the up arrow key.
    I couldn’t find anything similar, so I thought I’d ask if anyone has heard of anything like that.
    Michael Ron replied 11 years, 3 months ago 3 Members · 3 Replies
  • Paul Boone
    June 18, 2015 at 5:33 pm
    Ok.. I guess the shortcut is option + UP arrow key.
    I ran into media limits because the audio and video were connected. Ideally I don’t want to disconnect the audio from the video, but I suppose in this stage I could disconnect them, and then reconnect them later.
    Any workflow suggestions are appreciated. Thank you!
  • Brian Dow
    June 18, 2015 at 5:34 pm
    You have to edit/map the Nudge up keyboard short-cut.
  • Michael Ron
    June 22, 2015 at 8:29 am
    You can also just disable linked selection while you move the video clips to V2, than turn it back on when you’re done – That way your clips will still be selected and the keyboard shortcut will work, but you wont have to manually unlink and relink all your audio clips.
