Activity Forums Apple Final Cut Pro is there a hot key to turn the audio lane on and off?
  • is there a hot key to turn the audio lane on and off?
    Posted by Byunggi Yi on January 5, 2021 at 3:18 pm
    if it is please let me know guys~
    if not, i would say that The hot key of the audio lane is supposed to be made by.
    it would be absolutely useful.
    Joe Marler replied 5 years, 8 months ago 3 Members · 3 Replies
  • Mark Smith
    January 8, 2021 at 2:41 am
    I am not using X right now so I can’t say for certain, however there are many customizable commands available in X that go well beyond the standard keyboard commands in terms of invoking variations functions within the app. Easiest thing to do is open customize keyboard, do a search perhaps on ‘lanes’ and see what comes up. You may be able to create a command to toggle audio lanes.
  • Byunggi Yi
    January 8, 2021 at 9:47 am
    thank you for your reply
    i have searched so many times that i can do, but there is no way to use hot key.
  • Joe Marler
    January 8, 2021 at 2:26 pm
    I don’t think there’s a keyboard shortcut for turning a roll on/off. However in the timeline index you can show roles and during playback enable/disable specific audio roles.
    As always you can solo an audio lane using OPT+S.
    There are shortcuts to mute or silence selected audio lanes (or ranges) and also to restore those to normal volume. Those are not by default assigned to a key, you must use the command editor to assign those: https://support.apple.com/guide/final-cut-pro/solo-and-mute-audio-clips-ver717f57b4/10.5.1/mac/10.15.6
    Besides mute/unmute, you can disable/enable audio lanes with the V key. This is also range-based — you can drag a range over an audio lane with the R key and disable that range with V.
