Activity › Forums › Panasonic Cameras › Is there a FW ext hard drive option yet instead of using P2?
Posted by Blub06 on June 7, 2006 at 3:38 pmHas any company yet released an external hard drive that can record all flavors of the HVX-200 output? Is there one due this year?
Chris
Blub06 replied 20 years, 2 months ago 5 Members · 7 Replies -
David S.
June 7, 2006 at 4:29 pmAll flavors means p2 cards, or a drive that imitates a p2 card.
That would be the yet unreleased Cineporter.
https://www.spec-comm.com/cineporter.php
Blub06
June 7, 2006 at 7:58 pmI didn’t know the framestore thing did 1080p, I will revisit its web site.
The Cineporter thing is HUGH. I guess, all in all, its not as heavy as a full size camera though.
Chris -
Paul Nevison
June 8, 2006 at 9:55 amnot to be unkind but that cineporter is a BRICK! reminds me of the old says of having the tube camera on one shoulder and the record module slung over the other….oh yes its one step forward and two steps back 🙂
G5 DP 2.0
4.0G RAM
OS 10.4.6
QT 7.0.4
FCP 5.0.4
BMD Decklink Extreme 5.5.1
PAL Land -
Blub06
June 8, 2006 at 3:30 pmI looked at the firestore website and could not track down the model that would record 1080p 30fps. I emailed them this same question and if they have something I guess they will get back to me, if not, I will know because they wont get back to me.
Chris
Mitch Ives
June 8, 2006 at 4:05 pm[Blub06] “I didn’t know the framestore thing did 1080p, I will revisit its web site.”
You (and the others) are correct. The Firestore does not support all the modes. The biggest disappointment is the lack of native support. There is also the uncertainty of those FW codec chips in the mix and the lack of a secure (locking) cable system. The Cineporter (when/if) it arrives will eliminate those shortcomings.
[Blub06] “The Cineporter thing is HUGH. I guess, all in all, its not as heavy as a full size camera though.”
I guess I’m the only one that thought the FireStore mounting up on top of the camera looked more ungainly and caused more counter-balance issues than the Cineporter. Of course, having that hard drive motor and any fan right next to the microphone is exciting as well…
Mitch Ives
Insight Productions Corp.
mitch@insightproductions.comApple Certified Trainer: Final Cut Pro 5
Blub06
June 12, 2006 at 4:55 pmThey emailed me today with a pdf for the FS-100 which the tech specs say it does record in 1080i/p mode.
Chris
