Activity › Forums › Avid Media Composer › Is there a faster way to create DVD outputs?
  • Is there a faster way to create DVD outputs?
    Posted by Cathy G’nator on March 23, 2007 at 2:23 pm
    I’m outputting a 50 minute show from an Avid Xpress Pro on a Mac with Mojo to DVD screeners for a broadcaster. It takes about an hour to create a Quicktime and another 2 hours to create and burn the DVD using iDVD. The Quicktime ends up being a huge file–10GB and iDVD compresses it to 3.5GB which fits on a single disk. Is there another way to do this that won’t take quite so long? I’m working on a tight deadline and don’t want to give up so much editing time if I can help it. All suggestions welcome!
    Cathy G’nator replied 19 years, 5 months ago 6 Members · 7 Replies
  • 7 Replies
  • Michael Hancock
    March 23, 2007 at 3:07 pm
    If iDVD is on the same system as your Avid just export a Quicktime Reference file. It’s in a quicktime wrapper but will point to your MXF or OMF file directly, meaning the export from Avid is almost instantaneous. You’ll have to a wait just a little bit for the audio to export (it will mixdown your audio and export an aiff or wave file–your choice), but this shouldn’t be more than a minute or two.
    Michael.
  • Joe Womble
    March 23, 2007 at 3:56 pm
    You could always go the route of FW out of the Avid into a DVD recorder. It will give you the DVD in real time.
    Regards,
    Cre8tive
  • Bill Stephan
    March 23, 2007 at 5:27 pm
    Not quite real time! DVD recorders need a substantial amount of time to close a disc. The Phillips units in our facility need 30 mniutes to close a disc and the Panasonics need 45 minutes.
    Bill Stephan
    Senior Editor/DVD Author
    USA Studios
    New York City
  • Joe Womble
    March 23, 2007 at 6:18 pm
    I see! My Pioneer DVR-533H needs 3 minutes, and I think it’s approximately the same for the LX-1. Seems to be less if you have a smaller amount of free space left on the DVD.
    Regards,
    Joe Womble
  • Jon Zanone
    March 24, 2007 at 1:12 pm
    I’ve found the longer the video, the shorter the time needed to finalize a disc on my JVC recorder. I think there’s some multitasking going on. Then again, we’re sending the recorder a composite signal. I wonder if that has something to do with it.
    Jon
    “The Almighty tells me He can get me out of this mess. But He’s pretty sure you’re F%$#*D!”
  • James Sullivan
    April 18, 2007 at 9:50 pm
    For shows longer then 30 minutes the fastest way to layback cuts is to a consumer DVD burner. 3-7 minutes to finalize and you can duplicate from there. Avid takes for freakinig ever to make Quicktimes. Play and Record wait 50 minutes and your done..
    James
  • Cathy G’nator
    April 18, 2007 at 10:16 pm
    Thanks for all the info guys! I’ve been spending a lot of time making these darn DVD’s using AVID and iDVD–time to buy a proper recorder!
