Activity Forums Adobe Premiere Pro Is there a dither option for luma adjustments?
  • Is there a dither option for luma adjustments?
    Posted by Marc Brown on May 6, 2010 at 5:24 am
    Subject says it all.
    When I make an adjustment like Fast Color Correction or Luma Curve, Premiere Pro’s take on these functions is quick and very dirty, as is revealed by observing the result’s YC Waveform. Instead of a smooth wave, it’s split up into lines. And this effect does generate anomalies in the actual video.
    It’s understandable that a proper take on these adjustments would be more cpu-demanding. That’s fine; the end result is what matters. What I don’t get is that the option to enable dithering on these functions is not all that apparent.
    Options? ;p
    Marc Brown replied 16 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
