Activity Forums VEGAS Pro Is there a difference between adjusting the volume slider and adjusting a volume envelope?
  • Is there a difference between adjusting the volume slider and adjusting a volume envelope?
    Posted by Jaimie Hickes on February 22, 2018 at 4:30 am
    Aside from affecting the whole track vs specific parts, is there any difference between the two? Do they both affect the volume, or does one affect the gain? If I lower the volume slider to -5.0 dB, will it sound the same as lowering the envelope to -5.0 dB?
    Francois Pénzes replied 8 years, 6 months ago 4 Members · 3 Replies
  • Roger Bansemer
    February 22, 2018 at 9:12 am
    No, there’s no difference. I often adjust both.
    Roger
    Roger Bansemer – PaintingAndTravel.com
  • Steve Rhoden
    February 22, 2018 at 10:23 am
    No difference, it’s the same.
    Steve Rhoden (Cow Leader)
    Film Maker & VFX Artist.
    Owner of Filmex Creative Media.
    Samples of my Work and Company can be seen here:
    https://www.facebook.com/FilmexCreativeMedia
  • Francois Pénzes
    February 24, 2018 at 3:33 pm
    Hi Jaimie
    The only difference between the two is that the slider will take you from 0db to 12db and the volume envelope will only take you from 0db to 6db.
    The envelope allows for a finer adjustment.
    Cheers !
    PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz
    Cameras: Canon XF305 + Canon XH-A1
    Blackmagic HyperDeck Studio Mini
    \’\’When the cutting stops, the editing begins…\’\’
