Activity Forums VEGAS Pro Is there a Command for…expand/collapse ALL GROUPED audio tracks at once?
  • Is there a Command for…expand/collapse ALL GROUPED audio tracks at once?
    Posted by Stephen Mills on December 11, 2013 at 10:38 pm
    Just curious about this guys.
    I’m hoping I can expand ALL the “grouped tracks” at once with one click or command. When I double click on the scroll bar to the right it expands & collapses all the tracks but doesn’t open the “grouped ones”. Any ideas?
    Side note:
    I’m probably the only guy on this forum who uses Sony Vegas for just audio production as I find the program so much more intuitive & easier to use than Abobe Audition. I do a lot of elaborate work and it has been my main go to DAW for years even though it’s perfected for Video. (Mainly because of it’s integration with Sound Forge.) Weird huh?
    I’m using Sony Vegas 11.
    Stephen Mills replied 12 years, 9 months ago 2 Members · 2 Replies
  • Graham Bernard
    December 12, 2013 at 6:36 pm
    I believe you’re after this in the Help File:
    Grouping Tracks
    You can use track groups to organize similar tracks and hide them from view when you’re not working on them. This can make the track list less cluttered and easier to work with, especially in large projects.
    You can reorder track groups in the track list the same way you reorder tracks. Simply drag a track group header to a new position in the track list.
    Grazie
  • Stephen Mills
    December 12, 2013 at 7:03 pm
    Hey thanks… although not the info I’m after as I’ve already been doing that. I was hoping to be able to open all tracks (even the collapsed groups) at once with one click.
    It’ll only open groups that are already “expanded”…but not the ones that are currently “collapsed”
    I guess there’s no way to do it then. Thanks
