Activity › Forums › Adobe After Effects › Is there a clever work around to bypass 30.000 pixel buffer?
  • Is there a clever work around to bypass 30.000 pixel buffer?
    Posted by Jeremy Garchow on May 24, 2016 at 11:12 am
    I have tracking data from Mocha in which the corner pin information goes beyond 30,000 pixels.
    Is there a way to take this data, divide all the values by two, and then scale up the image to 200%? Or pergolas there is a clever way to make this data not go beyond 30,000 pixels, but still retain the tracking information?
    Walter Soyka replied 10 years, 4 months ago 2 Members · 3 Replies
  • Walter Soyka
    May 24, 2016 at 8:40 pm
    Does Red Giant Warp (which is supposed to be compatible with Mocha) also violate the 30,000 px limit with the same data?
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Jeremy Garchow
    May 24, 2016 at 10:17 pm
    Good idea, but not sure.
    I’ve been told I should try the stand alone version of Mocha Pro which will allow me to insert the clean plate and render it out as media, bypassing Ae corner pin.
  • Walter Soyka
    May 24, 2016 at 10:58 pm
    [Jeremy Garchow] “I’ve been told I should try the stand alone version of Mocha Pro which will allow me to insert the clean plate and render it out as media, bypassing Ae corner pin.”
    Yes, you should absolutely do that. I think you’d get benefit from Mocha Pro.
    Walter Soyka
