Is there 5.1 DD for HD ?
Posted by Joe Gaziv on July 12, 2007 at 3:39 pmHi,
Looking at the render options in Vegas 7, when AC3 format is being selected it rules out HD. Is there, at all, HD that comes with 5.1 DD ? If yes, what option needs to be selected for rendering ?Edward Troxel replied 19 years, 2 months ago 3 Members · 9 Replies -
Gary Kleiner
July 12, 2007 at 3:56 pmAC-3 is audio only, so there is no direct relationship to your HD video.
What is your plan for exporting your HD project?Gary Kleiner
Learn Vegas and DVD Architect
http://www.VegasTrainingAndTools.com
Joe Gaziv
July 12, 2007 at 8:41 pmI know that AC3 refers to the audio but if one would like to render SD video with 5.1 DD this should be his selection within the redner, isn’t it ? Well, I wonder what should be the selection if the video is HD (I thougth to play in on the PC since I do not have HD or Blue Ray DVD recorder).
Gary Kleiner
July 13, 2007 at 1:10 am[joe123] “this should be his selection within the redner, isn’t it ?”
AC-3 is rendered separatly from the video.
Gary Kleiner
Joe Gaziv
July 13, 2007 at 7:23 amOK. So on SD if one wants to end-up with DVD PAL with 5.1 DD he needs to have on the timeline Video part in mpg and Audio part in AC3 and render it all as DVD PAL – Right ? Will it be the same work flow while the Video mpg part will be HD ?
Edward Troxel
July 13, 2007 at 12:31 pmYou’re getting confused. Here’s what you do.
Edit your SD video on the timeline. Adjust the audio apropriately for 5.1
Once all editing is done, render the video to MPEG2 (appropriate DVD Architect preset – adjust bitrate as needed) and the audio to AC3.
Now in DVD Architect, create your DVD from those two files.
Joe Gaziv
July 13, 2007 at 1:51 pmHey, the original question was about HD – Where this one was gone ?
Edward Troxel
July 13, 2007 at 4:13 pm -
Edward Troxel
July 14, 2007 at 11:18 am
