Activity › Forums › Panasonic Cameras › Is the Audio Snyc issue fixed with the DVX100Bp
  • Is the Audio Snyc issue fixed with the DVX100Bp
    Posted by Ethan Saikin on March 28, 2007 at 9:17 pm
    I am working a project where people will be shooting with a DVX100b set to 24p mode we will be editing in a time base of 29.97 and not doing the advanced pull down. Editors will work at the same time in diffrent projects and platforms those being the most current verison of FCP and the Brand new osx AvidMediaComposer soft. I have read extensively the articles on the audio delay and how it is caused. However there is conflicting information in regards to when you need to adjust for it. Some documents say there is always a delay, others only if you are using the pull down methodology to get to a 23.9 time base. Final Cut believes the offset to be 2 frames the new version on Meridian soft v2.7 says that the offset is 1. I have also heard that the problem might have been fixed in the DVX100b. Also if the A frame is the only fame the contains a true frame of interlaced fields then must you also ensure you start digitizing on an A frame to avoid common stuttering issues you receive when digitizing film that was transferred to digibeta for instance?
    Thanks again
    Ethan Saikin replied 19 years, 6 months ago 2 Members · 2 Replies
  • Barry Green
    March 28, 2007 at 9:53 pm
    It was fixed in the DVX100A, and stays fixed in the DVX100B. There is never an audio sync issue with a DVX100A or 100B.
    Get the most from your DVX camera. The DVX Book and DVX DVD are now available on ebay and at Amazon (https://www.fiftv.com/db)
  • Ethan Saikin
    March 28, 2007 at 10:22 pm
    Thank you
