Activity › Forums › Apple Final Cut Pro Legacy › Is the a way to find a clip in a sequence
Posted by Baz Leffler on June 16, 2007 at 5:55 amIf I select a clip in a bin it there an easy way to find where it is in a sequence?
In Adobe Premiere you select the clip and go “find clip in sequence” but I am unable to determine the FCP equivelentBaz
What would I do without the ‘UNDO’ button!!!!
Noam Osband replied 15 years, 1 month ago 7 Members · 11 Replies -
Tom Wolsky
June 16, 2007 at 5:59 amNo, there isn’t/ Which sequence would it look in?
All the best,
Tom
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
Tom Wolsky
June 16, 2007 at 6:00 amOh, there is a find function in the sequence. So you could search for a shot in there.
All the best,
Tom
Shane Ross
June 16, 2007 at 6:00 amYou can do a FIND for the clip name. In the timeline, press APPLE-F and type in the name of the clip, press return.
Shane
Littlefrog Post
http://www.lfhd.net -
Baz Leffler
June 16, 2007 at 6:23 am[Tom Wolsky] “Which sequence would it look in?”
when you use “find in sequence” with Premiere it provides a pull down with all the occurances of the clip in any and all sequences; then you can click on any entry and it will open that sequence with the required clip selected.
Baz
Tom Wolsky
June 16, 2007 at 6:41 amNot in FCP.
All the best,
Tom
Shane Ross
June 16, 2007 at 6:54 am[BazinoZ] “when you use “find in sequence” with Premiere”
FCP isn’t Premiere…so many of the commands and features will be different. Premiere isn’t FCP…and it will lack much of what FCP does.
Shane
Littlefrog Post
Baz Leffler
June 16, 2007 at 7:01 am[Shane Ross] “FCP isn’t Premiere…so many of the commands and features will be different. Premiere isn’t FCP…and it will lack much of what FCP does.”
Yeah I am aware of all that although they are very similar in many ways also. Its just me coming to grips with both a new editing app AND a different platform. But the APPLE+F did the trick. Just as a matter of interest I need it as I am doing an online HDV conform from a project edited as DV from the down converted HDV. Just need it to check that it was all doing things accurately.
Baz
Andrew Kimery
June 16, 2007 at 7:10 amYou could also give the clip a color label in the browser and it will color all instances of that clip in any sequence it’s used in.
-Andrew
Roddy Jamieson
June 16, 2007 at 10:05 amLoad the clip into the Viewer and match frame.
Roddy Jamieson
Ron James
June 16, 2007 at 9:39 pm[adkimery] “You could also give the clip a color label in the browser and it will color all instances of that clip in any sequence it’s used in.”
This is indeed a handy tip!
