Activity Forums DaVinci Resolve Is Revival limited to a 1TB raid hard drive?
  • Is Revival limited to a 1TB raid hard drive?
    Posted by Henry Borchers on December 2, 2010 at 9:36 am
    I’m looking to set up a RAW drive system and I came across this in the manual “Revival may utilize drive sizes from 70000 (73GB) up to 1000000 (1TB RAID).”
    Does anybody know if the file system used in RAW is really limited to 1TB RAID or is that written in the manual only because it was the biggest drive available at the time the manual was written.
    Henry Borchers replied 15 years, 9 months ago 2 Members · 3 Replies
  • Gary Adams
    December 2, 2010 at 11:07 pm
    Hello Henry. This is an interesting question which I don’t exactly know the answer at the moment. If you give me a day or so, I can try to figure it out. I’m probably the one that wrote that but your assesment may be correct. There could be systems already running in this configuration that I am not aware.
    Regards, Gary Adams
    Gary Adams
    DaVinci Revival Product Manager
    Blackmagic Design
  • Gary Adams
    December 3, 2010 at 10:02 pm
    I did test configuring a raw disk on Revival and successfully initialized a 2TB disk. Since that manual text was written long ago (by me), it was probably talking about some of the drive configurations used at the time.
    I should add a minor word of caution here. The RAW file system has some benefits, however, is limited in performance and reliability due to the nature of the raw devices. This is why we recommend the Open File System using StorNext on a RAID5 or better system. Creating a huge RAW file system has the potential of losing a huge amount of data when one disk fails.
    Gary Adams
    Blackmagic Design
  • Henry Borchers
    December 5, 2010 at 1:20 pm
    Thanks for all the help.
    An updated manual would be much appreciated. Overall it’s very well written but I found a handful of areas that were either outdated or written in error.
    Also, while the manual is good as an overall reference, it is rather challenging to learn from it as a beginner. I don’t know what the best way of approaching this is. If it means adding a tutorial chapter to the manual that walks you through the entire workflow or if it means producing video tutorials, I don’t know. I do know that, judging from the streamlined controls and the powerful tools, the learning curve should be much less than it is.
    In any case, an updated manual would be much appreciated.
    Thanks again
