is project size related to FCP 5.1 crash?
G’day,
Without warning, FCP 5.1 refused to open today (with a corporate project due in two days). After a couple of hours of unsuccessful fidding around (e.g., deleting preferences, repairing permissions, reloading software), complete panic set in and I called Apple technical support. The support person advised removing and reinstalling the application, which ultimately worked.
My paranoia levels are extremely high now, because this is the first time an Apple product has been so undependable (e.g., refusing to open, no previous warning). Do you think the size of the project could be an issue? It’s a 19 minute video and it’s about 1 meg in size. Do you think the file size is too large and causing the application to choke?
It’s the first time I’ve used the Duplicate Master Clip, as I shot long clips (e.g., 2-3 minutes without stopping taping) and want to capture bits at the start, middle and ends of various clips. Do you think this could be an issue? Is using sub-clips a better way to go?
Has anyone experienced a similar problem?
It’s probably my own fault, but my confidence in FCP 5.1 is considerably shaken.
Thanks for your help.
Regards,
Doug
osx 10.4.6, dual G5 Tower, 2g memory
