Activity › Forums › Sony Cameras › Is live stream from PMW-200 into MacBook Pro via. FireWire possible?
  • Is live stream from PMW-200 into MacBook Pro via. FireWire possible?
    Posted by Evan Howell on February 26, 2013 at 3:38 am
    Hi, can this be done? I’ve read a few posts elsewhere that say this is a problem, at least for the EX-1, via HD FireWire. But as far as I know, the two cams are essentially identical. I’ve also read I need to shoot in FAT. Questions, questions.
    Can someone recommend what I need to worry about? Or do? The potential client wants a live stream from my camera into the computer via FireWire for a google ‘chat room.’ The stream will go for about 3 hours.
    Thanks very much in advance.
    Evan Howell replied 13 years, 6 months ago 3 Members · 3 Replies
  • Ian Cook
    February 26, 2013 at 3:26 pm
    yes, this is possible, just make sure:
    -FAT (EX) mode
    -record format is a 25 Mbps SP codec
    -i.LINK = enabled in OTHERS menu
    -i.LINK IO option selected in Video Set–>SDI/HDMI/i.LINK IO Select
  • Craig Seeman
    February 26, 2013 at 4:14 pm
    Since you don’t mention the age of the MBP, if it has Thunderbolt you can use a Blackmagic UltraStudio Mini Recorder and go HD-SDI straight out of the camera. If you do have an older Core2Duo MBP be aware that encoding HDV for a live stream is processor intensive.
  • Evan Howell
    March 3, 2013 at 3:25 pm
    Thank you for the confirmation!
