Is it worth going from Vegas 10 to 11?
Angelo Mike replied 14 years, 11 months ago 11 Members · 16 Replies
Dave Blankenship
October 23, 2011 at 5:01 amI just upgraded to version 11 from version 7, so you’ll probably still get the upgrade deal for version 12 if you sit this one out…
Nigel O’neill
October 24, 2011 at 3:04 amI have taken the upgrade path from v10 to v11, but probably will not install it until 11b or 11c.
I am still on 10c as it does exactly what I need. Sure, it does crash now and again, but it has never failed me on a render since version 8. I cannot say the same for Avid, Premiere and Pinnacle, which I have used in the past and failed to render. I don’t get paid if I can’t produce the goods. I would rather put up with the odd crash than not be able to produce anything at all.
I save regularly and hit Ctrl-S almost out of habit, so I usually do not lose more than a couple of minutes work, sometimes none at all.
To Angelo Mike, I am mystified as to what could be causing your issues, but as your are using your PC for other applications including Internet browsing, one of the following could apply:
- interference from your virus/firewall software
- installation of a CODEC pack <- These are very bad for Vegas
- corruption of Vegas system software from other software installs
- a virus
- Use of an unsupported CODEC eg DIVX in a project
- etc
Keeping your editing system clean is a must, especially if you intend to run a business from it, therefore a second editing workstation is a must.
My system specs: Intel i7 970, 12GB RAM, ASUS P6T, Vegas Pro 10e (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
James Kumorek
October 24, 2011 at 11:20 amIt’s worth trying, but I did that exact same thing, and ONLY installed Vegas 10, and Vegas still crashed on me frequently.
Elvis Deane
October 24, 2011 at 6:50 pmI bought it the other day just to stay current and Vegas is my bread and butter, so I don’t mind forking over the money. But there really isn’t that much new for most users. I’m finding it slower than 10, though I don’t have a newfangled GPU yet.
The fourth feature down in the New Features list is a Star-Wipe, so you know they went all out 😉
Elvis Deane!
Impossibilia
John Rofrano
October 25, 2011 at 12:34 amIMHO, the biggest new feature is GPU Acceleration. If you can’t take advantage of that, then the isn’t much left except that all of the Sony plug-ins have been converted to OFX which gives you more keyframeable control. Those two things right there should be worth it but as I said, if you don’t have a compatible GPU then that’s a different story.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Angelo Mike
October 25, 2011 at 6:05 amHopefully reinstalling Windows fixes the issue. And I know what a codec is, but what’s a codec pack? Are there any settings for my antivirus (Eset) that I should check?
Also, Vegas does require you to register it online to use it-do you just connect your computer to the internet for that?
