Activity Forums Apple Final Cut Pro Legacy Is it true that we should not rename clips from XDCAM EX3 ?
  • Is it true that we should not rename clips from XDCAM EX3 ?
    Posted by Fredy Schwerdtner on May 20, 2011 at 12:10 am
    I’ve heard that we should not rename the clips Logged & tranfered from XDCAM EX Cards taking the risk of nevere more being able to relink any footage …. We stay with many clips named with a bunch of number and on a long sequence on timeline we can’t see or say if any particular clip of the sequence belongs or not to, for example, to Scene 15 recorded.
    Is it all true ?
    Thanks.
    MacBook Pro 17″
    2.5 GHz Intel Core 2 Duo
    4GB 667 MHz DDR2 SDRAM
    (2) External HD LaCieMac (400/800 FW and USB)with 500GB -(2) USB External HD Western Digital (in cases) with 750GB
    OS X 10.6.5
    Final Cut Studio “3”
    Andrew Rendell replied 15 years, 3 months ago 2 Members · 1 Reply
  • Andrew Rendell
    May 20, 2011 at 7:13 am
    You can rename the clips in FCP7 as clip name and file name doesn’t have to be the same. You have the option to rename the files to match the clip name (which you don’t want to do) or rename the clip to match the file later. I think this was the case with FCP6 as well, but not before that though.
