Activity Forums Apple Final Cut Pro Legacy Is it suppose to take this long?
  • Is it suppose to take this long?
    Posted by Chris Baldwin on May 19, 2006 at 7:28 pm
    So I have a G5 dual 2 gig with 3 gig of ram and a 1TB sata raid.
    I’m trying to convert a sample 3 minute test clip of a DVCPRO50 show using Quicktime Conversion out of FCP5.whatever the lastest release is. It says its going to take 18 minutes to convert! WTF! Nothing else running on my Computer… So the full hour and a hlaf show is going to take 10 hours? Come on! Really?
    Let me just cut to the chase.
    I’ve got an hour and a half of DVCPRO50 16:9 video and I need to post it on Google video. I want to post it as a Quicktime file at the best quality possible the Google can deliver and host, while still having it stream to the viewer for easy un interupted viewing on atleast a DSL line.
    From FCP5 what program should I use to output this new file? Quicktime Conversion? Compressor? How do I retain the native 16:9 asspect ratio but reduce the screen size to Google’s preffered size. and an hour and a half should be how big of a file?
    Thanks!!!
    Chris Baldwin
    Shoulder High Productions
    Media of the World; For the World!
    https://www.shoulderhigh.com
    newsletters@shoulderhigh.com
    Jan Taylor replied 16 years, 11 months ago 3 Members · 3 Replies
  • David Bogie
    May 19, 2006 at 8:34 pm
    I cannot imagine Google allowing you to mount 90 minutes of video without charging you lots of money but I’m not in that business.
    > I’ve got an hour and a half of DVCPRO50 16:9 video and I need to post it on Google video. I want to post it as a Quicktime file at the best quality possible the Google can deliver and host, while still having it stream to the viewer for easy un interupted viewing on atleast a DSL line. < They've got specs. >The fastest way to get your videos included in Google Video is to submit each file in our preferred format. We accept video in AVI, ASF, QuickTime, Windows Media and MPEG formats, however, we currently do not accept Flash files. Specific video codecs we accept include H.264, H.263, MPEG 1/2/4 and motion JPEG.
    > From FCP5 what program should I use to output this new file? Quicktime Conversion? Compressor? < Compressor will do the job nicely. Transcoding from high rez to a highly compressed format using a different codec can take from 4-to-1 up to 10-to-1 ratio. If you've got a 90 minute DVCPRO50 file, you could be looking at a full day of encoding. It's a very complex process that depends totally on CPU. > How do I retain the native 16:9 asspect ratio but reduce the screen size to Google’s preffered size. and an hour and a half should be how big of a file? < That's not possible to guess from here. Compressor is certainly up to the task but you may not like it. If you open up the settings in Compressor you will see there are dozens of adjustments, filters and tweaks you can apply. Encoding for "best possible", like many other esoteric practices in this business, is best left to a trained and qualified specialist. Hire this done by someone who does stuff for google. Or plan on doing it five or six times yourself. You can use one of the h.264 settings for DSL as a starter and work on a small 2-4 minute clip that has a range of exposure and motion content. This is not going to be easy the first few times but you will get to a point where encoding, transcoding and uploading are second nature. you just need to learn a new language that has nothing to do with video. bogiesan This is my standard sigfile so do not take it personally: “For crying out loud, read the freakin’ manual.”
  • Chris Baldwin
    May 19, 2006 at 9:01 pm
    ok now I’m trying to use compressor to make a sample clip and it says “Error: An internal error occurred: ContentAgent server not found.”
    There’s no mention of this error in the manual.
    Chris Baldwin
  • Jan Taylor
    October 31, 2009 at 12:19 pm
    hey chris,
    do you solve the problem in 2006? i have actually the same with compressor 3.0.2. 🙁
    best regards
    3CCD
