Activity › Forums › Adobe After Effects › Is it possible to use the current value of an expression
  • Is it possible to use the current value of an expression
    Posted by Andy Bay on November 16, 2009 at 1:35 am
    Hi!
    Is it possible to get the current value that the expression has produced so far and refer to it with expressions?
    For example I would like to create an if/else statement that would tell x-position to increase only until it’s value is 100 and stop after that. How would I tell AE to use the x-position value that the expression is producing?
    Ryan Hill replied 16 years, 10 months ago 3 Members · 2 Replies
  • Xinlai Ni
    November 16, 2009 at 2:25 am
    Whether using expression or not, position[0] always tells you the x position.
    Xinlai Ni
    Software Engineer, Google Inc.
  • Ryan Hill
    November 16, 2009 at 7:46 pm
    Based on your example, you’re not asking for the current value, but the previous value, in the sense of the value that this same expression generated at a different time, so you can make a cumulative effect.
    My understanding is that AE doesn’t like to derive a property from itself on the basis that it could lead to circular reasoning.
    Here’s a similar problem where someone created a While loop to sum all the values from the start to the current time:
    https://forums.creativecow.net/thread/227/10015
    It isn’t referencing the result of its own expression, but another expression, but the results are similar to what you want.
