Activity Forums DVD Authoring Is it possible to swap VOB, IFO, BUP files from another DVD?
  • Is it possible to swap VOB, IFO, BUP files from another DVD?
    Posted by Craig Hirshberg on August 2, 2005 at 10:04 pm
    Basically, I’ve made a dvd in Encore, and I burned a separate dvd straight from my NLE to a Samsung DVD recorder of the same two videos.
    The compression of the Samsung recorder is better, so I’d like to somehow swap/replace the correct Encore files with the necessary Samsung files within the VIDEO_TS folder, and burn a new DVD with Roxio, all the while preserving the menu and linking functionality of the Encore project.
    Is this even possible?
    I’ve tried some different combiantions, some don’t work at all, others just play the videos without the Encore menu coming up.
    Craig
    (I’ve also posted in Encore DVD forum if that’s cool. Isn’t there a way to post in more than one? Just curious.)
    Craig Hirshberg replied 21 years, 1 month ago 2 Members · 2 Replies
  • Bill Stephan
    August 3, 2005 at 4:19 pm
    Rip the VOBs from the version you like down to the elementary streams, and then swap the resulting MPEG-2 & audio streams in the Encore project. Then burn a new DVD. This kind of change needs to be done at the authoring level. Don’t screw with the files on the DVD unless you have the tools to do it (such as TFDVD).
    Bill Stephan
    Senior Editor/DVD Author
    USA Studios
    New York City
  • Craig Hirshberg
    August 3, 2005 at 4:34 pm
    Thanks for the response.
    Actually, someone from the Encore forum clued me in that I can just import the VOB file back into Encore and replace the original Quicktime Refs with the VOBs I like – Worked great!
