Activity › Forums › Adobe After Effects › Is it possible to somehow automatically visually stack/separate multiple images either top to bottom, or left to right?
Posted by Aza Allen on July 11, 2013 at 5:59 pmI have 42 photos and I want to basically create a scroll out of them as though to look like one very long sheet so I can animate it like a ribbon, or something similar…
Is this possible? I’d hate to have to do it by hand, and if this works, I may be asked to do more like this…
Thanks all!
My portfolio can be seen at http://www.ruesterprod.com
My personal website is http://www.azaallen.comJoseph W. bourke replied 13 years, 2 months ago 4 Members · 6 Replies -
John Cuevas
July 11, 2013 at 9:01 pmThis could be done using expressions, but I’m having a bit of trouble working out the math now…try the expressions forum, I’m sure Dan or Kevin could work it out pretty quickly.
Johnny Cuevas, Editor
Thinkck.com“I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
—THOMAS EDISON on inventing the light bulb. -
Joseph W. bourke
July 11, 2013 at 11:31 pmIf you figure out the math in advance for the size of the comp you’ll need, based on the size of the images, you should be able to just place the first and last images, then use the Align and Distribute feature in After Effects to do the heavy lifting:
Just make sure they’re the same size, or you might get some unexpected results.
Joe Bourke
Owner/Creative Director
Bourke Media
http://www.bourkemedia.com -
Mike Zimbard
July 12, 2013 at 2:39 amLook into echo space from Red Giant if you have a little extra spend. It’s $70 and is absolutely incredible at controlling and organizing large groups of layers very quickly and easily.
https://www.redgiant.com/products/all/trapcode-echospace/
Good luck!
John Cuevas
July 12, 2013 at 2:24 pmActually worked out the math, so if you had 42 pictures and dropped them into a comp, you could paste this expression all of them except the the top layer—the expression calculates position based on the layer above it, won’t work on the top layer(no layer above it). So the top layer will be your control layer. This will work with different size pictures
startPos = thisComp.layer(index-1).transform.position;
w= ((thisComp.layer(index-1).width)+(thisLayer.width))/2;
startPos + [w,0]Here’s a quick example project I made: 6258_offsetpositionexpression.aep.zip
Aza Allen
July 12, 2013 at 3:10 pmThank you guys! I will try this expression out (I thought echospace was a layer replicator? not multi layer controller)
My personal website is http://www.azaallen.com -
Joseph W. bourke
July 12, 2013 at 4:25 pmFrom what I know, you’re right about Echospace. I own it, and have never known it to do more than duplicate the same layer. For really powerful arrays and manipulation of layers, PlaneSpace does some incredible things. Bit of a learning curve, but not bad at all. You can do stuff in minutes that it would take hours to do otherwise:
https://www.redgiant.com/products/all/planespace/
Joe Bourke
Bourke Media
