Activity › Forums › Apple Final Cut Pro Legacy › is it possible to ‘soft edit’ a clip? – IE: capture LONG clip – use EDL to ‘cut’ it up… OR use EDL to create markers?
  • is it possible to ‘soft edit’ a clip? – IE: capture LONG clip – use EDL to ‘cut’ it up… OR use EDL to create markers?
    Posted by Justin Tan on November 2, 2006 at 8:52 am
    Hope I’m not asking to much, but basically what I want to do is the following…
    capture in a long clip – IE 60minutes, then load an EDL or something similar and use that to ‘cut’ the clip up.
    In smoke you are able to do this by loading the clip into a sequence/timeline set up the timeline so it’s start time is the same as the EDL and then hit a button (so to speak)…
    Is there something simlar for this?
    Otherwise is there a way to use and EDL/ALE to create marker points in a TL?
    thx
    Misha Aranyshev replied 19 years, 11 months ago 3 Members · 5 Replies
  • Shane Ross
    November 2, 2006 at 9:40 am
    Not that I know of. But that sounds like a handy feature for color correction.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Misha Aranyshev
    November 2, 2006 at 10:12 am
    There was a third party utility that did this trick. I can’t remember the name.
  • Misha Aranyshev
    November 2, 2006 at 10:30 am
    EDL Mirror by Digital Heaven
  • Justin Tan
    November 4, 2006 at 11:25 am
    Sounds like what I need Mishka – will check it out…Do you know if it will name the marked point according to the name in the EDL?
    Thx.
  • Misha Aranyshev
    November 4, 2006 at 1:37 pm
    As far as I remember it simply creates new EDL that references master tape, not source tapes. It doesn’t changes event names, just TC and Reel.
