Activity Forums Apple Final Cut Pro Legacy Is it possible to save Log and Transfers queued files somehow?
  • Is it possible to save Log and Transfers queued files somehow?
    Posted by Andreas Karoliussen on September 7, 2010 at 8:20 am
    I´ve had FCP quit on me sometimes, and causing my logging info in log and transfers queued files to be lost.
    Logging arn´t that fun – and when done once I don’t like doing it all over again.
    I´ve read in the manual, tried to save the project. Drag from L&T queued files to browser. However cant find a way to save my logging.
    Should be able to export as xml or save log file – before transferring.
    Or is it an easy and obvious way to do this, that I have missed out on?
    Thank you.
    Andreas
    Andreas Karoliussen replied 15 years, 8 months ago 2 Members · 2 Replies
  • Steve Eisen
    September 7, 2010 at 1:19 pm
    Save early, Save often. If you are experiencing frequent crashes, get FCS Maintenance Pack from Digital Rebellion. Use their Preference Manager if you don’t want to spend the cash.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Andreas Karoliussen
    September 8, 2010 at 7:31 am
    Thank you for your suggestion, however as far as i know – saving a project does not save the queued log files.
    This seems a bit odd…
    So saving does not help.
