Activity Forums VEGAS Pro Is it possible to retro a project back to V10 from V11 – I HOPE !!!!!!!!
  • Is it possible to retro a project back to V10 from V11 – I HOPE !!!!!!!!
    Posted by Don Cobble on November 19, 2011 at 9:00 pm
    I have a project nearing completion. started to put titles in – both Boris Continuum and Title Pro from new blue instantly crash my project. Is there anyway to get my project back to version 10??????
    Thank U
    PC
    I7 2.8 Ghz 8GB Ram
    Win 7 Pro 64bit OS
    PNY Quadro 4000
    3-4 TB HD
    Vegas 10 64bit & Vegas 11 64Bit & Adobe Production Premium CS5.5
    Camera
    Sony EX1 shoot in 1920×1080 30P
    Don Cobble replied 14 years, 9 months ago 5 Members · 8 Replies
  • 8 Replies
  • Graham Bernard
    November 19, 2011 at 10:12 pm
    I’ve been reading on the SONY Forum NewBlue crashing VP11. I think you need to read more around the subject. Contact NewBlue.
    Grazie
  • Kevin Mccarthy
    November 19, 2011 at 10:43 pm
    Don
    I have an issue with VP11 in that The “render as” window has no text, only little empty boxes for letters. Sony is still scratching their head on that one and I had a project I had to finish. I opened VP10 and VP11 at the same time, “selected all” in the time line of VP11 and pasted into the time line of VP10. Now I have the clips in VP10 and I saved it as a different veg file. It worked for me so it may be worth a try. Good Luck!
    Kevin
  • Jim Schuchmann
    November 19, 2011 at 10:45 pm
    Open project in V11, Open a V10, Cut and Paste chunks from V11 to V10.
    You may loose some effects but better than starting all over.
    Good luck.
  • Don Cobble
    November 19, 2011 at 11:04 pm
    tried to do that but it didnt work – it is a 1 hour project loaded with stuff – I am open to any ideas
    PC
    I7 2.8 Ghz 8GB Ram
    Win 7 Pro 64bit OS
    PNY Quadro 4000
    3-4 TB HD
    Camera
  • Frank Stevn
    November 20, 2011 at 12:41 pm
    20 days ago opened a support ticket with NewBlue because it crashes in VP11. They sent me a logged version and I sent them the log files. Still no answer.
    Try to copy events to Vegas 10 little by little. Most of them will copy OK.
  • Don Cobble
    November 21, 2011 at 3:29 am
    Sir Frank, tell you a work around I have been able to use till they get the NB Titler and V11 crashing fixed.
    I have found that if I open another event of Vegas 11 and have an empty project and build the title with NB Titler Pro in an empty project it does not crash, then I save it as a Veg file, then import that veg file, into my active project (Both running at same time) the title preforms without crashing my master project.
    If I try to build the exact same title in my active project it crashes my project with in 2 or 3 adjustments.
    this is a few more steps but works for now
    PC
    I7 2.8 Ghz 8GB Ram
    Win 7 Pro 64bit OS
    PNY Quadro 4000
    3-4 TB HD
    Camera
  • Frank Stevn
    November 21, 2011 at 1:34 pm
    No luck. New empty project. Just drag NB to the time line and Vegas crashes.
  • Don Cobble
    November 21, 2011 at 4:04 pm
    Frank this is what I received from NB support – give these a try:
    “First of all, are you on the most current version of your video driver?
    When did you download Titler Pro? If it was after 10/24, you have the most current bundle version we’ve released for Vegas.
    What happens if you right-click a video track, choose “Insert Generated Media” and then choose NewBlue Titler from that list?”
    PC
    I7 2.8 Ghz 8GB Ram
    Win 7 Pro 64bit OS
    PNY Quadro 4000
    3-4 TB HD
    Camera
