Activity Forums VEGAS Pro Is it possible to remove black and white lines in the video around object?
  • Is it possible to remove black and white lines in the video around object?
    Posted by Sergey Woropaew on March 29, 2023 at 3:56 pm
    Is it possible to remove these black and white lines that visible most around woman’s head (and other objects in the video)?Is it possible to remove these black and white lines that visible most around woman’s head (and other objects in the video)?
    Aivis Zons replied 3 years, 5 months ago 2 Members · 1 Reply
  • Aivis Zons
    March 30, 2023 at 11:08 pm
    If the source footage is purely digital – you don’t have access to the original, this is all you have – then I’d say that the only thing you can really do in vegas pro is applying a Denoiser effect and if necessary Flicker Control.
    Won’t get rid of the lines, but might clear everything up quite a bit.
    You could try to duplicate the video track, offset it horizontally a bit and maybe with the right effects and compositing modes you can “improve” the look, but I’m fairly skeptical. That would more likely be a “different” look rather than a “better” one.
    If you do have the physical source recording, then a lot of it is down to the hardware used to digitize this. Better hardware – better results, noticeable difference.
    Alternatively you could try using some AI tools, such as Topaz. There should be a free trial available to test it out, but if you have any questions, don’t hesitate and head over to the AI forum
