Activity › Forums › Adobe After Effects Expressions › Is it possible to “read” the number of lines in a text box?
  • Is it possible to “read” the number of lines in a text box?
    Posted by Samuli Alapuranen on August 3, 2007 at 2:58 pm
    Could someone tell me if it would be possible to have an expression that would “read” the number of lines (or paragraphs) in a text box?
    What I’m trying to achieve is a text layer that would have 1-4 lines of text (depending on the amount of information needed) and a solid behind the layer that would adjust its height or position according to the amount of the text.
    Sam
    Samuli Alapuranen replied 19 years, 2 months ago 2 Members · 2 Replies
  • Colin Braley
    August 3, 2007 at 4:31 pm
    Try applying this expression to the scale property of of the solid that is behind each text layer:
    //begin expression
    textLayer = thisComp.layer("A Text Layer");
    scalePerLine = 70;
    //scalePerLine is how much to increment scale by for each newline
    newLineChar = '\r';
    newLines = 0;
    for( i = 0 ; i < textLayer.text.sourceText.length; i++ ){ if( textLayer.text.sourceText.charAt( i ) == newLineChar){ newLines++; } } //-- [value[0] , value[1] + newLines * scalePerLine ] //end expression
    Just make sure textLayer refers to the right text layer. Then adjust scalePerLine until you have the desired look.
    However, there are a few problems with this expresson. First of all, whenever a new line of text is added the scale property increases linearly when in fact it should increase according to some kind of exponiential function. This is beacuse, to make a layer n pixels bigger, you can't just add n to scale. I don't have time to fix this right now, but if anyone wants to give it a try feel welcome to.
    ~Colin
    http://www.colinbraley.com
  • Samuli Alapuranen
    August 3, 2007 at 6:14 pm
    Thanks! I’ll give this a try.
    How about changing Y-position instead of Scale? It would make it easier to have exactly the same value for each line.
    Sam
