Activity › Forums › Apple Motion › Is it possible to publish the stabalizer effect back into FCPX
  • Is it possible to publish the stabalizer effect back into FCPX
    Posted by Chris Lambert on May 8, 2013 at 1:46 pm
    This may seem like an odd request but I am currently able to stabalize footage in a multicam clip of an event that I am editing in which one of the cameras was a bit wobbly.
    When I click on the clip in FCPX inspector there is currently no option for stabalizer a quick google search shows that this is not a isolated find.
    Rather than have to go into the angle editor and apply the effect to the entire clip which I would imagine would take up a lot of analysis time as well unnesecary HDD space is it possible to publish a Motion effect using only the stabalizer effect back into FCPX so that I can grab this from the effects pannel and drop it onto the timeline of the cut that requires it?
    I am overly familiar with publishing effects and have only basic work in this in the past but I cannot get this to work at the moment is this possible?
    Mark Spencer replied 13 years, 4 months ago 2 Members · 1 Reply
  • Mark Spencer
    May 8, 2013 at 6:02 pm
    No, you can’t publish a Motion effect that stabilizes. Why not locate that clip in the event, set a range for the shaky part, and stabilize it there? It should pass through to your multicam edit automatically.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
