Activity › Forums › Apple Final Cut Pro Legacy › is it possible to monitor hd through an m10u
Posted by Cade Muhlig on July 2, 2006 at 10:02 pmthe m10u is a hd device, but i cant preview out in hd. i can in sd, but my project is in hd. if thats not possible, is there some other way that i can monitor onto a crt?
Walter Biscardi replied 20 years, 2 months ago 4 Members · 7 Replies -
Cade Muhlig
July 2, 2006 at 10:05 pmalso, i can set up a project in sd, preview it through the m10u to a crt, then switch over to a hd project, and it’ll display one frame at a time. its a horrible way of doing it, but i gotta do what i gotta do.
Shane Ross
July 2, 2006 at 10:50 pmThe only way you can view HDV to an external monitor is to get an HD capture card…or the Matrox MXO when it comes out. But then you need a monitor capable of reading an HD signal. Or a card capable of sending out an SD signal to an SD monitor (Kona 2, Kona 3, Decklink Extreme HD) . And know that the SD image is in no way accurate for color correction.
HD is a whole new monster.
Shane
Alokut Productions
http://www.lfhd.net -
Cade Muhlig
July 3, 2006 at 2:44 amim sending the signal through firewire to a hdv sony tape deck then out to a tv, so why doesnt that work?
Walter Biscardi
July 3, 2006 at 2:48 am[cadobee] “im sending the signal through firewire to a hdv sony tape deck then out to a tv, so why doesnt that work?”
sounds like the deck doesn’t have EE or it’s simply not set up as a pass through device for Firewire viewing.
I know on our 1200A DVCPro HD, monitoring through Firewire is simply not possible due to sync errors. If I send an HD-SDI feed to the deck, the image is fine, but not with Firewire.
As Shane said, HD capture card like the AJA Kona series is what you want.
Walter Biscardi, Jr.
https://www.biscardicreative.com“I reject your reality and substitute my own!” – Adam Savage, Mythbusters
David Slater
July 3, 2006 at 8:55 amHDV doesn’t work like that as it is a MPEG 2 long GOP there are only 2 real frames for every second of video
it is very processor intensive and as such can’t be monitored via FW as you wish
a AJA card would offload the processing of the HDV signal and would allow you to monitor the video in realtime like the others saidDAVE at Movies Rock in Toronto
Walter Biscardi
July 4, 2006 at 2:46 pm[cadobee] “those sure cost a pretty penny!
thanks for the info”The AJA cards? For HD work? Nope, they’re incredibly cheap. Go price an HD Avid and see what you can get for $3,000. If you’re working in HD, your first job should pay for the card.
