Activity › Forums › Adobe After Effects › Is it possible to make the composition background transparent
Posted by Chris Gu on March 27, 2006 at 11:19 pmI can only change the background color but not to transparent. Any help?
Deniz Maslowski replied 6 years, 9 months ago 9 Members · 15 Replies -
John Dickinson
March 27, 2006 at 11:21 pmClick on the little checkerbox button at the bottom of the comp to hide the background color.
JD
John Dickinson
Motionworks
http://www.motionworks.com.au -
Chris Gu
March 28, 2006 at 12:09 amWhile it hides the background color if I export the movie the background color still exists. You’re talking about the “Toggle Transparency” button right? That one doesn’t work.
Andrew Kramer
March 28, 2006 at 12:12 amViewing the tranparency and rendering transparency are 2 separate issues. To render with transfarency you need to use a codec thats supports alpha.
When rendering check to see if the channels are set to rgb plus alpha. Quicktime animation is a popular method. I tend to use PNG sequences for most things.
Good Luck
John Dickinson
March 28, 2006 at 12:13 amYou have to choose an output format that supports alpha channels, Quicktime Animation is one, Targa sequence is another
Serge Hamad
March 28, 2006 at 12:14 amChris,
When exporting your movie you have to choose a codec that supports an Alpha Channel. QT Animation set to Millions of collors plus does for instance.
Salut.
Serge -
Justin Productions
March 28, 2006 at 12:17 amOkay, if I understand well your question…
Adobe After Effects shows transparency as a black color. So when you import a file, wheter it’s a picture [(below the size of the main comp for example, so you see black (tranparency) around)] or a video footage that you keyed and you see some black under it, that’s the transparency. Just do Composition > Make Movie > Output Module > Quicktime (any format…etc.) and be sure to render with RGB + Alpha.
Black = Alpha in a certain way.
If I didn’t answered your question, just tell me (or us).
Hope that helped.
Justin Productions
Tangerin01@hotmail.com
Adobe After Effects 6.0 Professional -
Justin Productions
March 28, 2006 at 12:19 am*Rofl!*
Now, I just hope he got his answer!
Justin Productions
Chris Gu
March 28, 2006 at 1:04 amI don’t think what I asked made the most sense. Basically, I have a black background (for my composition) just like it would be set to for any new composition you make in AE. Then I just have a simple timer in white down at the bottom. All I want to do is have the timer in white and leave the background color black out of it (of course making it transparent)
So do I even need to bother toggling the transparency button?
Because everytime I go to render, and I’ve tried almost everyone’s method listed above – It looks transparent then shifts to black as it’s rendering (which means whatever settings I used didn’t work)
So am I missing something? I’m re reading your posts as we speak but I don’t know why this is so difficult for me lol.
Chris Gu
March 28, 2006 at 1:28 amOh and part of why I don’t want to use like png or targa is because it makes so many individual files… and I need to put my video in reverse. I need to put it into reverse because the freaking timer preset I used in AE I couldn’t set it to go in reverse. So I don’t want to have a bunch of images I’d need to manually move around.
I’m using 6.5 by the way…
I go to composition … make movie … (Look at the render queue) and scroll down to output module. Click output module and then go to Quick Time Movie
The only channel options I have are RGB or ALPHA not both together…
Any help?
