Activity › Forums › Adobe After Effects › Is it possible to make effects end on the same position as in the start of the composition?
  • Is it possible to make effects end on the same position as in the start of the composition?
    Posted by Mathijs De Nooijer on July 30, 2020 at 6:51 pm
    I’m trying to create a seamless loop for an animated twitch overlay. If I use the cutting/transparency technique you can still clearly see where I made the cut. So I was wondering if perhaps it’s possible to force an effect to “work towards” the same position as where it started at the beginning of the composition.
    Not sure what terms I should use to look for the answer here.
    Blaise Douros replied 6 years, 2 months ago 2 Members · 1 Reply
