Activity › Forums › Adobe Premiere Pro › Is it possible to lower music volume in Source Monitor?
  • Is it possible to lower music volume in Source Monitor?
    Posted by Dustin Bowser on June 25, 2010 at 10:44 pm
    In Final Cut Pro I would always have to double click a music file and lower the volume by about -12 DB because music it also mastered much louder than production audio. I was wondering, is there a way to do this in Premiere, so that whenever I’m going through potential music tracks I don’t constantly have to keep riding my volume levels on my audio monitors.
    My output levels of my sequence are -12DB, but all my music is at 0DB, which means that every time I double click a song to audition it, it’s super loud and I have to turn down my audio monitors, and then turn them back up when it comes time to edit. In FCP it wasn’t a problem because I would pull up the song, turn the volume to -12, and then from then on it was always -12, and if I edit it into the timeline it will come in at -12.
    Anyone have a suggestion for this?
    Jon Barrie replied 16 years, 3 months ago 2 Members · 1 Reply
  • Jon Barrie
    June 26, 2010 at 1:29 am
    Yes this can be done.
    It’s best to assign a shortcut for the function.
    With the audio file in the source, go to the edit menu and find audio options… Then select audio gain…
    Set the -12dB overall and hit OK.
    The entire clip will now be -12dB less than it originally was. It is not set with a levels band like FCP so be aware of the difference in execution.
    – Jon Barrie 😉
    Jon Barrie
    aJBprods
    http://www.jonbarrie.net
    http://www.suiteskills.com
