Activity › Forums › Adobe After Effects › Is it possible to interpret keyframes?
  • Is it possible to interpret keyframes?
    Posted by Mark Jobe on August 12, 2010 at 10:58 am
    I have a clip in AE with a frame rate of 29.97 and several layers containing masks and numerous keyframes. However the original footage needs to be interpreted to 24fps. Is there a way to also interpret the layers so that the keyframes on the masks fit and the extra keyframes are somehow deleted?
    Chris Wright replied 16 years, 1 month ago 2 Members · 2 Replies
  • Mark Jobe
    August 12, 2010 at 1:55 pm
    Thanks for replying. I usually do make sure the footage is at the correct frame rate before anything else. This happened as a result of a bit of a breakdown in communication with the client. We seem to have resolved the issue using the time stretch option though.
    Thanks again
    Mark
  • Chris Wright
    August 12, 2010 at 8:33 pm
    maybe another option was timewarp or twixtor your final render so that the framerate changed but not the speed. just a thought.
    https://technicolorsoftware.hostzi.com/
