Activity Forums Adobe Premiere Pro Is it possible to install Magic Bullet Looks into Premiere Pro?
  • Is it possible to install Magic Bullet Looks into Premiere Pro?
    Posted by Michael Vance on July 22, 2022 at 1:57 pm
    Is it possible to install Magic Bullet Looks into Premiere Pro? I have tried everything imaginable and MBL only appears in After Effects, not Premiere Pro. I guess there have been some changes since Maxon took over, but has anyone successfully installed MBL into Premiere, and if so can you give some tips for installation into Windows 10 like what folder it should be installed to and where to looks to see if it tried to install something?
    Court Leve replied 4 years, 1 month ago 2 Members · 1 Reply
  • Court Leve
    July 22, 2022 at 3:14 pm
    I was able to do it on my Mac into PP but it wasn’t intuitive at all. Sorry I can’t help how, just letting you know that at least on a mac, it’s possible. Worth noting. If you don’t keep your subscription active on projects that you haven’t clips that you’ve used MB on will be unavailable. You’ll have to remove the action from each and every clip.
