Activity Forums Adobe After Effects Is it possible to have an effect similar to the one on the video “Black or White” by M. Jackson?
  • Is it possible to have an effect similar to the one on the video “Black or White” by M. Jackson?
    Posted by Deborah on January 3, 2006 at 11:24 am
    If I remember well on that video there were a “special” dissolvence on faces.
    One face became another one but not with a simple dissolvence, it was something more, almost a “morphological” effect!
    I wonder if we have same effect also in AE.
    Debbie.
    Deborah replied 20 years, 8 months ago 3 Members · 3 Replies
  • Airpot
    January 3, 2006 at 11:42 am
    I think it’s solved with somekind of morphing tool.
    There is quite good morphing tool called RE:Flex by RevisionFX
    https://www.revisionfx.com/rflx.htm
    Maybe you should try that out.
    -Marko
  • Ken Knowles
    January 3, 2006 at 2:18 pm
    I haven’t seen the video you are referring to, but if it is a kind of morph you could probably use RE:Flex by RE:Vision Effects. It is a plug-in for AE.
    Ken
  • Deborah
    January 4, 2006 at 8:23 am
    Thanks a lot! Unfortunatly it’s quite expensive!
    Debbie!
