Activity › Forums › Adobe After Effects › Is it possible to have a wiggle that creates hold keyframes?
  • Is it possible to have a wiggle that creates hold keyframes?
    Posted by Daniel Haskett on November 7, 2007 at 1:26 pm
    Hi there,
    Say you apply a wiggle (2,10) its gonna move 2 times a second and 10 magnitude…..but inbetween those 2 keyframes it tweens or whatever its called, moves around. is it possible so that the motion is more jerky, so it actually only moves twice a second as though it were 2 hold keyframes….does that make sense?
    cheers
    dan
    Kevin Camp replied 18 years, 11 months ago 3 Members · 4 Replies
  • Steve Roberts
    November 7, 2007 at 2:23 pm
    You could convert the expression to keyframes, then select them all and convert to holds, or maybe precomp the layer then apply Posterize Time …?
  • Daniel Haskett
    November 7, 2007 at 2:43 pm
    the problem with converting to keyframes is that it converts all the inbetween keyframes, so there arent just 2 keyframes per second if u know what i mean?
    cheers
    dan
  • Steve Roberts
    November 7, 2007 at 3:19 pm
    So maybe post in the Expressions COW — there may be a way of holding the results of the expression.
  • Kevin Camp
    November 7, 2007 at 3:32 pm
    will precomping the wiggle layer and then applying posterize time as steve mentioned not work for you…?
    it’s probably the easiest way. you’ll just set the posterize time effect to the desired framerate (in your case, 2 fps) and you will get exactly what you want.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
