Activity › Forums › Compression Techniques › Is it possible to get a 16:9 output from 1440×1080 footage?
  • Ian Liuzzi-fedun
    May 26, 2012 at 11:06 pm
    If you are talking about sd-then yes. Export to compressor-drag the dv anamorphic setting onto it and ensure you crank up the resize filter and motion estimation filter
