Activity › Forums › Adobe After Effects › Is it possible to edit a footage file path without replacing it, using javascript?
  • Is it possible to edit a footage file path without replacing it, using javascript?
    Posted by Siddhartha Nayanananda on August 20, 2018 at 5:15 am
    I have a big amount of Ae projects that has missing footage problem. I already made a script to find and replace missing footages but still needs to go through PSD layers because I didn’t find a way to script it to replace and link specific PSD layers. So
    Is there any way we can edit file paths that saved in a project file? Without going through replacing them?
    Like, Foundry nuke has a path section that we can always edit to direct it. sorry for bringing nuke to the discussion but could someone let me know? Thanks. Cheers!
    Siddhartha Nayanananda replied 8 years, 1 month ago 2 Members · 2 Replies
  • Walter Soyka
    August 20, 2018 at 2:30 pm
    If you use File > Save as > Save a copy as XML, you’ll be able to use standard text tools to search and replace file names in the resulting AEPX file.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Siddhartha Nayanananda
    August 20, 2018 at 5:41 pm
    Hey Walter,
    Thank you so much for taking time to replay. Seems like this is the only way to do this. Thanks again for the help.
    Cheers!!
