Activity › Forums › Adobe Illustrator › Is it possible to do a stroke without curved edges?
  • Is it possible to do a stroke without curved edges?
    Posted by Daniel Haskett on May 14, 2007 at 12:10 pm
    Hi there
    Well basically when you apply a layer style to a layer with a stroke, it always gives the stroke rounded edges….is it not possible to have on with straight edges if it is for a box for instance? i know when you choose “inside” it kind of does but then u loose the edges of the image…
    thanks in advance!
    dan
    Mike Gondek replied 19 years, 4 months ago 2 Members · 1 Reply
  • Mike Gondek
    May 14, 2007 at 2:59 pm
    Sorry but stroke layer styles setting to inside is the only way to do this, and I have been pushing these type of bread & butter features on the Adobe beta’s for years.
    Illustrator works much better for strokes. You can copy your photoshop stroke into illustrato as a vector path, stroke it in illustrator and then bring that in as a smart object. I fill with the illustrator path same color incase I am off by a pixel.
