Activity Forums Apple Final Cut Pro Legacy Is it possible to deinterlace video with qt7pro & h.264?
  • Is it possible to deinterlace video with qt7pro & h.264?
    Posted by Toke on June 16, 2005 at 4:49 pm
    Does the deinterlace check in clips properties affect only in playback or also when exporting dv compressed mov to h.264 mov?
    I used to encode dv to 3ivx mp4’s with qt6 and there deinterlacing worked.
    I’m not sure if deinterlace was done in exporting or just playbacking those mp4’s, but it worked.
    Now with qt7 deinterlace setting in properties does nothing to h.264 clips.
    Does qt7 think that h.264 is already progressive and that’s why it does not do deinterlace?
    There’s no scan mode setting in h.264’s compression settings as there are in dv settings.
    I would need to compress many hours of interlaced multicamera footage to h.264-mov and I’d like to skip importing and exporting to FCP only for deinterlace, if possible.
    Toke replied 21 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
