Activity Forums Adobe Audition Is it possible to cut down room echo?
  • Is it possible to cut down room echo?
    Posted by Jeffrey Gould on January 7, 2006 at 4:36 am
    Not really sure how to explain this,but I shot a video in an OR of a Dr. doing an on camera testimonial and the sound has the quality or lack there of an empty room, I used a lav, but they had scrubs on and the mic wouldn’t really stay where I wanted it…so the mic could’ve been closer to their mouth. Is there any effect in Audition that would compress the echo sound? Thanks for any direction.
    Jeffrey S. Gould
    Action Media Productions
    Jeffrey Gould replied 20 years, 7 months ago 3 Members · 4 Replies
  • Willie Toth
    January 7, 2006 at 11:51 am
    Jeffery,
    Sorry, once it’s there it’s almost impossible to remove …. WILLIE
  • Jeffrey Gould
    January 9, 2006 at 9:26 pm
    Figured so…but apprecitate your reply.
    Jeffrey S. Gould
  • Axel Rogge
    January 11, 2006 at 10:26 am
    I think it depends… You will not be able to get rid of the whole echoes, but maybe you can shorten them with a ducker. Try to analyse the echoes frequencies (which must not be the same as the voices, because of room reflections) with a parametric equalizer and filter them out.
    Or – if it
  • Jeffrey Gould
    January 17, 2006 at 9:49 pm
    Thanks Alex, I’ll try your suggestions. Perhaps echo was the wrong term, more of a auditorium (large room) effect…same result though.
    Jeffrey S. Gould
