Activity › Forums › Apple Final Cut Pro › Is it possible to Convert .MOV to MP4 with no loss in quality
Chris Wright replied 4 years, 5 months ago 15 Members · 16 Replies
Chris King
April 22, 2022 at 4:29 pmI disagree with you. A lot of free video conversions online are not free.
Michael Alberts
April 24, 2022 at 3:13 pmBeen using this trick for years. As long as you encoded the .mov with the h.264 codec it should work. There was a time not so long ago that all h.264 .mov files exported from FCP would not import into PremierePro. It simply refused. If you just change the .mov to .mp4 PremierePro would instantly recognize and import those files. This is true of many “smart” monitors as well. We’d send .mov’s to clients for playback on their “smart” monitors in their booth at various trade shows. If the monitor wouldn’t recognize the file we’d instruct them to change the file name to .mp4. Works every time. It’s just a wrapper. The internal codec is what’s important.
Greg Ball
April 25, 2022 at 7:31 pmI always output my videos straight from FCPX to MP4 with a .h264 wrapper. The quality is excellent.
Flemming Sorvin
April 26, 2022 at 5:20 pmIt’s a good question really.
The real answer is no. You can’t export to H.264 from your production codec (ProRes, or in your case DVCProHD) without a loss of quality. There will always be *some* loss due to compression.
But what you can do is make good choices along the way and minimize the effect of compression.
So, what I would suggest is use the best encoder out there for H.264: x264. It’s used by all the big players (encoding.com, YouTube, Netflix, Hulu, etc.) not just because open-source and free to use but because it’s the most tuneable and produces the best image per bitrate.
Luckily for us, there’s an easy and free way to use it: Handbrake (https://handbrake.fr).
Export your master to ProRes if needed, or drop your DVCProHD into it and choose your preset. It comes with a set of Production presets (standard, max, etc.) which should do you just fine, and will do all the x264 tuning for best quality.
For uploads to web services, like YouTube or Twitter, the service will re-encode your video, so why not give them the best you can before they compress the hell out of it for their delivery?
If you want to take this to the next level, you can build in an Export to Handbrake command from FCPX. I’ve got instructions on how here:
http://fsorvin.freeshell.org/01articles/2017-03-06_export_to_handbrake.html
Hope that’s helpful.
Flemming
Chris Wright
April 26, 2022 at 5:36 pmi’d also note free shutter encoder (pc/mac) has a feature called rewrap, that changes the container without touching the video data.
