Activity › Forums › Apple Final Cut Pro › Is it possible to Convert .MOV to MP4 with no loss in quality
Posted by Daniel Ladeira on May 14, 2012 at 3:05 pmHi there everyone.
Here’s the deal, the client have difficulty with mov files in their enterprise. So he asked me for the video in AVI or MP4.
The AVI i am not even considering
The mp4 i just can’t keep the same quality. Sharpen lines and stuff.
I am using MPegStreamclip, or Compressor, h.264 compressor for MPEG4, and aways losing too much in quality. I know i won’t have the same as the original .mov but is ther anyway i can keep at least the sharpen edges?
Anyway, thanx for ur attention
Daniel Ladeira
Chris Wright replied 4 years, 5 months ago 15 Members · 16 Replies -
Marco Feil
May 14, 2012 at 4:39 pmWhat Codec is used in the .mov files?
If it’s already h.264 in a .mov container you could try remuxing the files without encoding. for example with “remux” https://www.macupdate.com/app/mac/35968/remuxif you have to encode to h.264 I recommend trying handbrake https://handbrake.fr/
It’s very easy get good results using handbrake.
try the high profile preset – and constant quality RF 20-23 for HD, or RF 24-28 for SD content (lower RF = better quality). -
Richard Herd
May 14, 2012 at 4:42 pmThere’s a compression forum that’s pretty useful, and there’s a lot of detail to wade through.
You’re going to lose some image quality just because of the nature of the formats. So keeping things perfect is a very detailed process.
First, you need a high quality original.
Second, you need to use Compressor (not MPEG Streamclip). -
Daniel Ladeira
May 14, 2012 at 5:04 pmThanks people.
Well. the original is DVCPRo 1280×720
I expoerted it using quick time current settings from the timeline, some time ago. Now i have to convert it from the movie.
I usually use the compressor. I friend of mine gave me the tip of using the mpegstreamclipe, but i didn’t like the result very much.
When exportig for web and stuff i use the h264 and it fits good.
I’ll take a look at the forum to see if i can find something.
Do u know this wondershare video converter?
https://www.wondershare.com/mac-video-converter-ultimate/?icn=vcumacI was told it’s amazing, but don’t know it yet
Thank’s again.
Daniel
Gary Smith
May 14, 2012 at 9:38 pmI did this with a .mov file
1. Open in Quicktime
2 Go to File and open Export
3 In Format choose 720p
4 FCX then finds this when you open the location you save it to.
Best I could work out -
Dave Gage
May 15, 2012 at 2:16 amDaniel,
You might also check out the x264 plug-in for Compressor, QT 7, etc. instead of the standard H.264 MP4. The quality and encoding speed is as good or better than H.264 with smaller file sizes.
Here’s a thread from about 6 months ago about it-
“The x264 open source alternative to the H.264 Apple encoder”
https://forums.creativecow.net/readpost/344/5782I use it mostly to create .MP4s from Compressor and occasionally from QT 7. It really is as good as advertised. It’s less of any issue if posting a video to Youtube or Vimeo, but if you serve it from your own website, it’s saves a lot of bandwidth over time. Myself or someone else here can help you with settings if you have questions.
Dave
Dysonk Jack
August 3, 2013 at 3:20 pm -
Jack Adision
April 14, 2014 at 9:51 amMP4 video files are doesn’t supported by many video player devices but don’t worry because you can play MP$ video file on any portable video player. Simply convert MP4 to MOV and after conversion play MOV video.
Chris Alderson
July 20, 2015 at 12:33 pmI can recommend the app I used to convert MOV AVI to MP4. As far as I know WALTR app is comparatively new and easier than others. It converts at fast speed and with original video quality. I think it’s worth using! ..especially for those, who don’t want to waste time 🙂 Here is some info https://softorino.com/waltr/best-converter-avi-mp4-mac-windows Hope it’ll help you)
Berti Bruyn
June 27, 2017 at 2:24 amActually, there are many online apps can convert MOV video to MP4 video, such as zamzar, Acethinker Video Converter, mediaconverter, etc. They are totally free, and you don’t have to download or install anything.
Rikki Blow
June 27, 2017 at 10:52 amI’m the world’s idiot on codecs, but I’ll throw in a crazy idea that might just work.
I export 1080 movs from FCPX regularly, but require an mp4 version for posting on twitter – MOVs simply don’t upload on that platform.
So, on a Mac, I simply rename the .mov to .mp4, and say yes when the warning pops up, and hey presto, it uploads to twitter and plays fine.
Clearly no data loss with that method.
Whether it will work on files your client needs, I don’t know, but it might just be worth a try.
Happy for someone to point out why this is working for me on twitter, and/or the general error of my ways.
