Activity Forums Blackmagic Design Is it possible to capture analog on a Extreme HD?
  • Is it possible to capture analog on a Extreme HD?
    Posted by Derrick on May 20, 2008 at 6:27 pm
    Hi there,
    I have a DeckLink Extreme HD (purchased in Dec ’07).
    Do I have to have a SDI signal coming into the device, or is there a way to capture from composite signal? (RCA, i have a converter plug from RCA – to the connectors used on the card and breakout cable)
    I want to capture some old family video tapes for a friend to write them to DVD?
    thanks for your help
    – Derrick
    Derrick replied 18 years, 3 months ago 2 Members · 2 Replies
  • Dan Sparks
    May 20, 2008 at 11:20 pm
    Use the “Y” cable of the component input and hook that up to your VCR with proper adaptor. Then set your Decklink System preference pane to composite input.
    Dan Sparks
    Tricom Video
  • Derrick
    May 29, 2008 at 3:23 pm
    Thanks Dan,
    Now I understand my card a lot better, and your solution wors 100%.
    I appreciate it,
    Derrick
